- 14 April 2007
- Shropshire, UK
- www.lupix.co.uk
To save people asking the same questions and for those wanting to deviate from the norm for more 'high performance' choices, I'm going to list what I'm changing to in terms of gearbox/diff oils and brake fluid etc
I don't want to start a 'which is better than the other' debate but this is what I will have running soon as I've got 100% trust in the person who has given me their advice based on knowledge and experience of using said products in similar environment (track & drift) :thumbs:
GEARBOX OIL
Redline Heavy ShockProof 75W-140
http://www.opieoils.co.uk/p-1023-redline-heavy-shockproof-gear-oil-75w-140.aspx
DIFF OIL
Fuchs Titan Race SYN 5 75W-90
http://www.opieoils.co.uk/p-68901-fuchs-titan-race-syn-5-75w-90-fully-synthetic-gear-oil.aspx
BRAKE FLUID
Motul RBF600
http://www.opieoils.co.uk/p-894-motul-rbf-600-factory-line-racing-brake-fluid.aspx
I'm gonna do the gearbox oil this week and the 'heavy' factor should help to preserve the gears a bit more and ShockProof will help with combating stresses from clutch kicking and launches etc. Believe gear changes will be 'stiffer' and more notchy when cold but I'm willing to accept this for better gear preservation when it's hot and being driven hard.
Diff oil I'll be swapping out the Redline Heavy currently in there for Titan SYN 5 fully synth as I reckon a slightly less sticky/viscous fluid will allow the diff to operate better within a drifting arena. Ever since I swapped for the Redline Heavy the diff has not felt right - it actually feels sluggish at times. It could be a problem with an older worn diff but I'm not convinced since she drifts well when going fast but when I need her to break traction at low speed it's not been the same as it used to be before the oil was swapped :wack:
Brake fluid wise - this will be done when I get the K-Sport calipers fitted but again the Motul has been recommended as way better compared against the Ferodo DOT 5 which I currently have and boiling points are apparently higher.
GEARBOX OIL
DIFF OIL
BRAKE FLUID
Motul RBF600
