if so check the lamp, the lamp spring retainers for tension or blackness and the switch for any blackness on the contacts. if youy are swapping for an led interior lamp then make sure the polarity is correct
once again, deans15 you have solved my problem!!!!checked the fuses in the footwell like you said and there was one gone.for anyone with the same problem its the second red 10amp fuse on the bottom row.cheers again deans15
by the way - without nicely - i wouldnt have known either! all credit to that man, hes the reason i have the board diagrams in the first place! i resized and laminated the diagrams from the useful threads and stuck them to the underside of the lids so ill never get stuck. ill get some pics if you like, but its sort of as its read
