Fuel Pump Install
superbike81
Getting ready to install a Walbro 255 fuel pump. Was looking at the fuel pump cover last night in the car and there are wiring connectors going into the top. Which one will I splice the fuel pump wiring into? Why are there two connectors? I'm not used to seeing this, every other car I've done a fuel pump on has just had one.
Thanks for the help!
if you're fitting a walbro pump then dont worry there is no splicing to be done. the standard plug on the original pump plugs into the walbro without any modding.:)
May I suggest you read the guide on my site before doing anything? Most of those connections on the top are fuel lines.... A Walbro is nearly entirely plug and play on the S15 (its not on the S14).
subzero
2 June 2007
Limerick Ireland
ah was on you page and only went through your s15 guide. very very helpful page that .
so stick with your existing fuel filter if its in good nick ? and is a fuel regulator needed with fitting this ??
subzero
2 June 2007
Limerick Ireland
so just the pump is all i really need as my motor i reckon is unmollested except for a metal head.
thanks buddy.
