Flywheel bolts
I've got an ACT organic clutch and ACT Prolite flywheel ready to go in at the weekend, but after Nissan quoteing me £70 for the 8 bolts, is there another solution?
I've read on SXOC that people re-use the original bolts, but are s15 bolts useable with a ACT fly?
Cheers fellas
_Wing_
24 August 2006
if it's an s15-specific clutch kit then yes the s15 bolts work... only s15 bolts will work actually.
you can reuse your bolts but you run the risk of having your legs chopped off :eek: seriously, they stretch, and if one goes the rest will follow... until the flywheel flies apart :wack:
i've searched around for aftermarket bolts but couldn't find any GOOD quality ones, I sucked it up and bought genuine ni$$an bolts
25 February 2006
East UK
I'm in 100% same situation. What did you do and where did you get um from. I need to source before Tues next week!!
I found out you can't use a s14 fly in the s15 s speed box, so you'll have to keep your dual mass s15 fly or get a s15 specific fly.
I ended up using the standard dual mass fly so didnt need bolts in the end.
25 February 2006
East UK
:eek:Apparently the ACT fly isn't as deep. The OE fly holds the spigot bearing and so the garage reckon the end of the output shaft hasn't anywhere to locate + the OE bolts are too long :eek::annoyed:
:confused:
The S14 ACT fly will not fit mate as i said earlier. I had to sell mine and stick with the OEM dual mass
sx-si
7 June 2008
hampshire uk
trial fit the fly can check for play
im surprised this issue only comes up here and not on many other forums
