Electrical issues - any ideas?
5 December 2007
Wellington, NZ
www.hoodoo.co.nz
I've blown six fuses in the last couple of weeks, from stereo to indicators off alarm, to one side of indicators regardless of alarm, to all indicators + hazards, and a couple of others.
Slightly undercharged battery, now recharged.
Took it to an auto-sparky, got charged $160 for a bunch of things that didn't need doing and they didn't isolate the problem either, because it's blown another fuse or two since then.
Any thoughts?
GUEST_JDM
um... well strange as it sounds try looking at your stez connections cause the indicator light main feed runs behind there just for starters, and if you have one on stand by use a cable toner as well from the side of lights that blew with out the alarm should help try pin point it
Strange that you would blow that many fuses so close together. Maybe the regulator in your alternator is playing up and putting out AC. If the systems are not related, ie. indicators and stereo, the only common point is the charging system / battery. That is where I would look first. Also have a look at your earths off the battery to the chassis. They could be loose.
