Hope you are enjoying your vacation, so I wont bother you too much
:wave:HEHEHE, i'm living here now for next little while
So this would explain why my engine runs higher revs when the lights are on if its running lower voltage? Is 300 ca enough? It is sealed.
:wave:Yeah, basically, your battery is doing nothing but starting the car. so when you turn lights etc on, you altenator has to do all the work. so it revs up to increase power.
Could I not open the hole up to allow a standard power cable? (obviously fill in the areas to stop leaking) If a standard cable went through would the lazy start disappear?
:wave:yes and no, the bigger the diameter of the wire the better, but there is about 3.5m between the fuse box and the boot. there will still be a lazy start, just not as bad. 2 meters of wire has twice the resistace of 1 meter of wire.
:wave:My concern about opening the hole, would be a risk of wear on the battery wire insulation. If the grommet was modified, it could fail.
I have a FMIC which is why I'm limited in size of battery and also I dont know if its a jap terminal (with the back against wing post is bulkhead/towards driver and neg is headlamp/FMIC).
:wave:'Jap terminal' is more to do with the size of the terminals, they're tiny compared to EU batteries. I sounds like your battery was replaced at the time your FMIC was fitted so that the teminals could reach. if that battery was in good condition, it could probably start a truck. If there is a three digit number like '053' etc, get another one like that.
How did you wire the clamps? I mean you have multiple wires going to your clamp for both pos and neg did you attach new cable into clamps and bolt clamps together or did you solder accordingly?
:wave:I bought a few different battery terminals at the local motor factor, the 3 smallest ones i think. the clamps had a large area for fitting a wire, so i put both wires in the each terminal and tightened it up.
Cheers, Keith
PS If I was to bridge can you bridge to a larger battery?
