J0R04N Joined 22 July 2010 Messages 528 Reaction score 0 Points 0 Location Backwards in a hedge near Oxford Country 30 July 2011 #1 What plug in does our cars use??? Is it an OBII?
J0R04N Joined 22 July 2010 Messages 528 Reaction score 0 Points 0 Location Backwards in a hedge near Oxford Country 30 July 2011 #3 Nice one. Just wanted a way of monitoring the ECU.
Tony Joined 3 March 2010 Messages 83 Reaction score 0 Points 0 Location sweden Country 12 August 2011 #4 I bought A Nissan consult,, but all i get is the message ( can't detect the device ) =) =).. anbody got same problem.???
C Controll3d Guest 12 August 2011 #5 Could be just system settings...? Which program you using for it?
Tony Joined 3 March 2010 Messages 83 Reaction score 0 Points 0 Location sweden Country 12 August 2011 #6 I.m using ScanTech Nissan..! Last edited: 12 August 2011
C Controll3d Guest 13 August 2011 #7 Recheck your com-port settings from programs. Do you have ignition turned to ON? I'm using EcuTalk and working fine. I think also Datascan found my ecu.
Tony Joined 3 March 2010 Messages 83 Reaction score 0 Points 0 Location sweden Country 13 August 2011 #8 My laptop only has 2 Usb ports,, So I end up using either port 7 or 8.. Have now downloaded Nissan datascan.. and will try that also later.. WhaT kind of Consult do you use..?? I haVE this. http://www.eobd2.com/wholesale/nissan-consult-diagnostic-interface.html and then I bought a rs232 to usb connector too.
C Controll3d Guest 13 August 2011 #9 Some programs doesn't seem to work properly with anything but com port 1. I have blaZt usb consult cable. Friend have that specific consult adapter with usb converter and seems to work aswell (with S14), but not sure which prog he was using.
Tony Joined 3 March 2010 Messages 83 Reaction score 0 Points 0 Location sweden Country 13 August 2011 #10 Just tested and It didnt work.... Hmm I'am thinking about buying a rs232 to vga cable and try with that,, or a Usb hub with 4 ports.. =) Last edited: 13 August 2011
