FS: Driftworks Polybushes
21 July 2009
United Kingdom
You my friend, are going to cost me a fortune :D ......what else would be needed just adjustable arms for adjusting the camber etc?
If you have adjustable camber arms then this kit is perfect as it will cover every suspension bush on the car apart from the Tension rods and diff mounts ;)
I'm only running 1 set of adjustable arms on the rear which are the camber. I thought about changing them all but my geometry is spot on so no need.
