diff question
29 May 2009
ireland
ok looking at buying a KAAZ 2way diff.5 bolt side shaft
its out off a s13,
and i found out that it will fit in r200 diff case
i own a s15 and want to know does my silvia have 5 or 6 side shaft?
thanks
6 bolt side shaft. Are you going to be drifting it or track work.
The 2 way will drive you nuts if your using the car on the street. Wait till you take your first roundabout with it :wack:
29 May 2009
ireland
6bolt thanks:notworthy: its my daily:wack: yea heard it can be quite tricky on the arse-mite have to go 1.5.what you running mate?
1.5 way Nismo TTpro. The two way can be a handful in the wet and coming out of tight corners. The clunking in reverse and on full lock is annoying especially when people keep telling you there's something wrong with your car. The 1.5 way is excellent for street and track work.
The 2 way is great for drift as it is easy to break traction because the inside wheel grips as hard as the outside wheel so both wheels will break traction evenly when you put the power down
