clutches
ShawnS15
hi guys,
i got a few question to ask..i ve got 2 choices in buying a clutch, 1 from exedy, 1 from cusco. both wanna get the organic/coppermix type.
1) which will be a better choice?
2) pedal efforts are the same?
3) how much it can hold?
regards,
shawn
exedy and cusco has a wide variety of clutches.
So you need to be a bit more specific which clutches you had in mind.
I would look into a clutch kit with flywheel and release bearing. My flywheel showed signs of overheating when I changed my clutch.
In fact I think it was the flywheel which caused the slipping. The clutch still had some go in it if I remember my friends comment who changed the clutch for me.
ShawnS15
i am looking for those heavy duty type/organic/coppermix type with stock s14 fly..
als_jordan
13 July 2007
I've been asking the same questions recently, I am just about to pick up my car monday with Exedy organic and a stock S15 flywheel.
Another recommended to me was the Exedy Hyper Single clutch and Fly kit... I didnt choose this option as I wasnt too sure about the driveability using a lightened fly??
I can feedback later this week if you like?
i can assure you now mate that after a day of using the exedy hyper single paddle kit - it is awesome:D
the pedal is as light as stock (with a braided clutch line) and only needs a little bit of concentration pulling away in first to begin with - took about two hours of driving to get used to and now i get on fine with it. driveability is still very good, piles on revs quickly, i really do rate this clutch from someone that was dreading a paddle - once you're out of first its superb.
the only negatives are reversing uphill can need some revs, and it may cause a little noise/vibration on decelleration but i am 90% positive that is my exhaust which at the moment is touching under the car. i even noticed that when left in second off clutch at very low speeds (going over bumps etc) it doesnt begin to judder until a very low speed, in fact so low a speed you'd be putting it back in first anyway:nod:
my opinion - 9.5/10 as nothings 100% perfect
Matt_S
The Exedy Hyper Single is a really nice clutch to work with. And can hold a few FtLbs too! ;) I had one on the S14 that I used to drift.
N
nices15man
sweet!! ive got one coming this week!
btw they can hold 400ps
25 February 2006
East UK
I've just worn out my Exedy paddle plate. Lasted about 15K with some drifting/track days, so pretty heavy use but pretty much standard torque/power (on the S15 ~ 270Nm). I would like to go back to the days of no clutch judder so the organic could be a good option as it should work with the spring/cover.
Experience of the 2 anyone?
Will anyother plates work with the Exedy cover?
