Clutch is making noise
17 March 2009
every time when I press the clutch when my car is still cold, it's making some kind of squeezing noise...
but when the car's warming up for a while, the noise will not show when the clutch is pressed.
is this a major problem?
my car is running 6 spd box, with after market flywheel, standard clutch if i recall it correctly.
any help would be appreciate
23 December 2010
Devon, UK
I'd start by just bleeding the system right through making sure all the old fluid is out. I had a similar noise and this cured it.. it's an easy job too. Not saying this is your problem but it may just do it..
17 March 2009
alright..i will check and put new fluid in and see what happens...
and if it's the release bearing that cause the problem..so i need to drop the gear box and grease the release bearing properly?...
1 May 2010
Wolverhampton
If its the release bearing you need to change it for a new one :nod:
Easy to change but a right pain in the ass to get too as its a box off job!
