Central Locking Fuse
18 August 2009
Hi guys - do you know which fuse the central locking runs on? Problem is my passenger side has stopped working, doesn't open from the alarm remote, nor the drivers door button or using the key in the drivers lock. so it's not both central locking units, just the passenger, does it run on a different fuse to the drivers side?
Had some battery problems and heard the passenger side actuator buzzing and hasnt worked since, so if it's not a fuse i am assuming the actuator has died?
I would say the actuator has died. I don't think they are fused separately.
stanletmontena
Every car has different fuses for different things. So unless you tell me which car it is, I cannot exactly locate it for you..
