Hi, yesterday i was cruising along the beach and when i found an empty space i floored it. i hit the rev limiter and since then my car runs only with the two middle cylinders. i say that because when i removed no1 and no4 coil it made no difference, when i removed 3 and then 4 the car was trying to die. i checked the spark plugs. 1 and 4 where wet. i changes all 4 of the, changed coils and ignitor. still the same problem. only 2 and 3 coils are firing.
might be the cas? injectors are ok probably because afr is around 10.
