FS: ***Breaking competition spec 1JZ S14 + Super garage clearout RB JZ SR S13/S14/S15***
4 August 2012
Surrey
Breaking complete car plus I'm clearing my ENTIRE Garage out with all the various spares i've gathered. - Keep checking back, as this thread will be updated frequently as I work my way through all the stuff I have. I have various high quality race car parts such as Laminovas, EWP, Slicks etc
I'm rarely ever on here, so please try not to flood me with PM's and/or offers. Give me a call or text on 07751203302 and i'll try get back to you.
All prices collected from Surrey (weekends) or Midlands (Mon-Fri) - Couriers can be arranged
I have photos of most items, but will only post on request
****COMPLETE DROP IN 1JZ Conversion****
Available as a COMPLETE package for a plug and play 1jz conversion.. If it doesn't sell anytime soon it'll be split down further, but only transmissions will be available as I will be keeping the engine for my next car ;)
If you are interested in certain parts PM/Call me and I'll put you on a list if it all gets split.. (please don't fill the thread with request for parts)
This was one of the first 1JZ conversion first assembled back in 2008 and since then has also proved to be one of the most reliable.
1JZGTE Engine
S-Body Engine & Trans Mount Set (Sit engine low & far back as physically possible) - Best on the market!!
Manifold Japspeed - Never Cracked
Machined Reducer T3/T4 - Tapered - For HX35
Wastegate 60mm GTll
T304 SS Screamer - Exits Front Wing (to suit the engine mount kit) Can easily be modified to bonnet vent/floor vent
T304 SS 3" Downpipe with Flexi (Z axis) & V-band Flange to Exhaust (to suit the engine mount kit)
Exhaust System - 3" T304 SS Pipe inc Flexi (X,Y Axis) - 1x Shotgun - 1x Backbox for Noise Regs (to suit the engine mount kit)
GSR Holset HX35 - Mint condition!
PTP Turbo jacket
Oil Feed and Return for HX35
Monster Pipercross Air filter & Intake Pipe
Boost Pipes (to suit the engine mount kit) (2 pipes, 4 clamps) Shortest IC pipework going
3" Intercooler Bar & Plate
Radiator pack (60mm Rad - Sealed Cowling - OEM Twin Fans) Never overheats even on sustained track abuse
Mishimoto thermostat 65C
Thermal Intake gasket
Power Enterprise Injectors 550cc (Recently Cleaned & Tested) Includes one brand new spare.
Tomei Head Gasket
ARP Head Studs
Modified Rocker Covers & Oil Breathing System
Water pump
Alternator
Power Steering Pump and Proper Bracket (Decent Pump)
Power Steering Pipe Work & Cooler
LS2 Individual CoilPacks & Magnecore KV85 Lead set mounted on Dry carbon plate
Front sump - Shallow rib design with turbo drain - Lowest sump variant available
All seals recently replaced.
Notes: History of the engine from day 1.. Engine had sub 100k kms when I removed it from a soarer many yrs ago.. Stripped down and rebuilt with skimmed head, laped valves, full Toyota gasket kit from top to bottom.. Engine ran 485hp @ 1.6bar 495 ft/lbs for 4yrs..
At the beginning of this year I stripped the head, skimmed and laped valves, valve stem oil seals, Tomei Head Gasket, ARP Head Studs, etc.. Now running ~470hp @ 1.4bar.
Engine has started to smoke a tiny bit. Believed to be valve guides. Potentially piston rings as the bottom end has never been disturbed. Spare set of pistons and rings will be included.
I have cold compression test results available ~5-8psi variance across cylinders
Haltech Platinum Sprint 500 Standalone ECU
Comes with.. Water Temp Sensor, Air Inlet Sensor, 3Bar Map Sensor, and custom made wiring loom. Plug & Play for S14a
Was mapped by ProTuner to this engine & setup 6months ago.
R154 Gearbox - bought from Garage D
Evolution Lightweight Flywheel With Brand New Spare Core (Replacable Core) 11.5lb - lightest on the market
ACT Clutch Disc & Pressure Plate (has life left but would benefit from a new friction disc)
ARP Flywheel Bolts
New Slave Cylinder
Release hub with recently replaced bearing
Clutch Fork & Pivot
Shifter with Marlin Crawler Bushes
Prop (to suit the engine mount kit)
Bellhousing to Engine Bolts
Clutch to flywheel bolts
In short you get Complete powertrain & mounts, complete cooling pack (Rad, Fans, IC, Oil cooler), full exhaust system, management etc. Everything you basically need to get your S chassis going. At this package price I'm also willing to throw in or do good deals on any other parts.
***~£6500 open to reasonable offers depending if you didnt want certain parts***
Split down price of drivetrain
ARP Flywheel Bolts
New Slave Cylinder
Clutch Fork & Pivot
Total £1950
I have a second gearbox which the thrust washer failed on. I started stripping it down ready to rebuild but never got round to completing. I also have a third gearbox which has a failed countershaft and 2/3rd gears - If this doesn't sell I will have my specialist complete the box with full MC rebuild kit and respective price.
£550
R33 Manual Diff Welded non ABS with relevant prop £160
Pair R33 Drive Shafts (inc N/S spare) £80
Various S14 rear props non ABS & ABS Variants £40 ea
S14 Manual Welded Diff (Mint condition, NO play) & Pair of good shafts (Inc 1 spare N/S) £120
S14 Rear subframe with body mount bushes removed. Whole frame painted - £70
S14 Front Subframe x 2- £50
S14 Front x2 steering rack with Polybushes - £50 ea
5x114 Hubs - Front - £140
5x114 Rear Hubs x 4- £100 for a pair
S15/S14 Custom spec'd Aragosta Coilovers fitted with Custom Bestex Springs & Helper springs NO OFFERS
Came off the Silk Road / Ikeya Formula Time Attack S15 (if you don't know what they are, they are wasted on you!). Have never been on the road, and only covered circuit miles. Very limited use, and in great condition. If your looking for a serious coilover and want to know more give me a call. In short they p!ss all over the genereic crap on the market atm
£1000
2x Walbro 255 Pumps £100
2x Bosch 044 Pumps £120
AH Fabrications 2L Surge tank £120
Sytec Serviceable fuel filter £50
Rubber overbraid 10mm fuel line ~5m - £40
Rubber overbraid 8mm fuel line ~4m - £40
***Bodywork & Interior***
S14 Roof spoiler (Perfect Fit)- £120
Chargespeed 25mm Wider front wings modified to single vent £100 some minor damage - easy repair
Vented Bonnet £100 some minor damage - easy repair
Monkey Magic Bumper £70 some minor damage - easy repair
4 x Doors with glass mirrors £50 each (2 black, 2 Green)
Chargespeed 50mm Rear Overfender Driver side £70
S15 Boot lid £80
Headlights £100 pair - One has the glass removed and been modified to act as a headlight duct.
Sparco EVO Seat FIA Approved out of date £120
Red Bride Bucket seat £160
Ricco 4 point FIA Black harnesses £70
Ricco 4 point FIA Red harnesses £70
