Hi guys as some of you may know my car has had a few running issues from the moment it came into the country, and ive actually done 63miles in it within the last 6 months, as the respray and prep took a little longer.
But anyway im now ready to get the boosting issues sorted but need to know relatively what could cause this problem.
If i pull away at normal temperature in first gear and floor the throttle hard the car will boost then get to around 3.5k-4k then judder/hit an imaginary rev limiter and will for a short time not boost, then go back into boost, but only to 5kish. All the way through to third gear.
Sometimes il get through the gears then in third/fourth gear it will get to 5k and quite literally make you feel like your going to headbutt the steering wheel?
No warning lights flash up on the dashboard or do i get any idea that its going to happen, it just does it like its meant too!?
If i repeat the procedure but go gently down on the throttle 'sometimes' the car will boost all the way through to 5.5k through every gear, But that is a very rare occurance, i have never been able to find the whole performance of the car and at the minute im classing it as slower than my jdm ep3!
Now i have fitted an uprated walbro, hks ssqv, it has a turbo elbow, sports cat, 3inch straight through exhaust, front mount intercooler, hks mushroom filter, nismo 2 way diff and a horrible stiff as you like race clutch.
I have gone through all the boost hoses and found a few have become a little perished, so have ordered every single hose that can be replaced including all intercooler hoses and vac lines.
But even just changing a few of the perished ones with some universal rubbish laying around never changed the way the car run.
I know this could be down to the fact that the car has clearly seen an aftermarket ecu before as there are signs of the loom being spliced before, but ive gone through the loom and made sure everything is connected and clipped properly and it all seems to be fine.
ive also put in new plugs but these didnt change the outcome.
I will be getting horsham developments to fit map and set up a nistune on the car, and im also thinking of getting some nismo 740's just as a measure of thinking the standard injectors arent up to the job.
Anyone got any other ideas on why this is happening? I really dont want to drive the car now as i dont want anything costly going wrong.
The importer that i imported it from has said that he will help out with what is wrong with the car but only on standard parts as everything i have just mentioned is 'effectively' a mod.
If this is going to cost to much il be breaking it/ selling it for nothing as it really is of no use to me sat on my drive with it maybe going to blow!
Please help lol
Please help lol
