boost problem
sniffy
27 February 2007
Co.Wicklow Ireland
i was at a rolling road day yesterday and may car was only boosting at .5 it wont boost any more and at about 5500rpm the boost seems to drop to .4 and stay there to redline where it then spikes to about .8. has this happendend to anyone else ? i checked for boost leeks cant find any it still only boosting at .5 anyone hve any ideas ill see if i can post up the dyno sheet. it only made 226bhp at the flywheel and 266nm torque.
j@garagemac
solinoid bust ??? or a split pipe from the turbo to solinoid ???
or at worst a broken actuator, make sure the little clip holding the actuator arm to the turbo hasn't come off
kind regards jamie
sniffy
27 February 2007
Co.Wicklow Ireland
i was thinking actuator myself im also getting a nosie back through the airfilter when i release the throttle it kinda like a dump valve noise.
j@garagemac
try taking the ssqv off and blocking up the hole i have had these leak befor
sniffy
27 February 2007
Co.Wicklow Ireland
heres the 2 dyno sheets. you can see on the first the boost is all over the place its the purple wavie line.
sushiming
13 November 2005
Hong Kong
is it still stock actuator?? i would invest in a hks one i did and solve my problem with my boost
as u have checked everything else already
sushiming
13 November 2005
Hong Kong
u would get it much quicker geting from apex uk theres not a big diff in price 89.99 if i remember rightly
sniffy
27 February 2007
Co.Wicklow Ireland
so that means the actuator isnt causing the boost problem. also i have removed the boost sender attached to the drivers side wing as i didnt think i needed this as i fitted a defi boost gauage.
sniffy
27 February 2007
Co.Wicklow Ireland
i have a question about the power fc boost control kit what i need to know is does the map sensor in the kit connect in to the same piping as the original boost sensor is just the harness for it wont reach that far i have it run to the power fc but the other end wont reach to the other side of the engine.
