Boost Leak (Not in the conventional places though..)
24 November 2009
North Yorkshire
First up, I know what the first answer will be to my problem "check your hoses". I have. I've checked every single hose from the turbo to the plenum. I've tightened them, re tightened them, i've connected an electric pump to the boost nipple and done a pressure test, and not found any leaks that way. So. Why is my car boosting to 0.6. It doesnt flutter, doesnt spike. Just hits a wall at 0.6. It used to go up to 0.7, spiking to 0.9 before i fitted my fmic.
The recirc valve is fine as far as i can tell (its a new Forge one)
Could the boost solenoid be shot? would that affect it? (its factory standard)
Or could it be the wastegate actuator? Would that affect the boost pressure? I just cant understand it!
Any wild ideas would be brilliant! Cheers.
17 May 2010
Brunei Darussalam
Perfectly normal in my book. Happened to me when I installed my FMIC. Installed a 1 bar actuator recently and it boosts to 0.8 max.
24 November 2009
North Yorkshire
have you got a new solenoid fitted too? I reckon the spikes of 0.9 might have nackered it up.. somehow.. but you never know.. it is a 10 year old part, and everything wears out eventually..
s15dave
does it go as fast as it went before?
the goal isnt to get the maximum boost, the goal is to get the maximum amount of air in your engine.
2 April 2011
- Albion -
www.driftworks.com
remove the solenoid and remove the crappy forge valve. Ideally, you need a boost controller or an adjustable actuator. I would reccomend an HKS one.
24 November 2009
North Yorkshire
well it doesnt boost as high as it did before and i havent got any readouts to compare speed to, however it doesnt feel as fast
what would be the difference between buying an adjustable actuator over a boost controller?
2 April 2011
- Albion -
www.driftworks.com
well they both achieve the same result, although a combination of both will be more accurate with regards to control. also taking into account that your current actuator has been not only next to, but phsyically attached to a fecking hot turbocharger!
24 November 2009
North Yorkshire
haha ok, so i take it aftermarket ones are relocated away from the turbo slightly?
2 April 2011
- Albion -
www.driftworks.com
no same position, but they haven't had thier diaphrams cooked for 10 years and thier springs going through a massive range of heat ranges! With a HKS actuator and a boost controller (i personally use the new HKS EVC-S, because it's simple and effective!) you will get crazy gains in response / low down torque. that's assuming you don't have some other issue, but i'd put money on the forge leaking...
24 November 2009
North Yorkshire
its not the BOV because i've checked it! haha i had the same problem when i removed the BOV completely and blocked the pipe (whilst doing a pressure test) so who knows..
