Boost Controller AIR FILTER?
I don't think it's necessary to fit it, I know Jez at h-dev never bothers... If you really want one I have one.
24 November 2009
North Yorkshire
Never even heard of these before! And now you've got me curious! Whats the story with them? Worthwhile or not?
Have you had one fitted to yours Dean?
Mine was never fitted, still got it. Had no problems in 3 plus years of use
8 May 2006
Dublin , Ireland
Those filters are generally included with electric boost controllers, pressure sensors and some BOV's.
I think all it does it fillter any particales which is in vacuum lines, so dust/carbon won't building up on the sensors. which should help make the sensor work at there best.
i had one of these fail on me as it split into 2 and cause a vacuum/boost leak.
25 January 2012
West London, UK
I've never seen these before but then again i'm pretty new to turbo cars, surely these would be detrimental to the response of a boost controller ?
For example after they have been in use for a while (or even new) the filter will to some extent impede the flow through the line to the boost controller resulting in less pressure getting to the boost controller meaning it will delay the response resulting in going past the desired boost level ?
