Just bought myself a blitz sbc-i-colour boost controller. Just wondering about installing it and internal and external wastegates.
The wiring im not to bothered think i can work that. It’s more the setting up of the relay. Im not hundred percent sure what pipe to T into. In the picture below where i have labelled “air in” is that where i plumb into the IN valve of the dual relay and the OUT is plumbed where i have labelled “actuator”.
Also I was wondering on the blitz cpu there is a piece of tube sticking out that has to be connected to a location where vacuum and boost can be acquired “connect to the surge tank or a location that generates vacuum at throttle off”
So wondering where i connect to, as well i take it that the bltz cpu is installed somewhere inside the car preferable near the cars cpu. Would running a pipe to it not lose its vacuum over that distance?
Finally was wondering about wastegate when setting up the controller it has to be set as (AC) actuator type or (WG) wastegate type and i am unsure which it is. I don’t have a blow off valve fitted but in the picture below i think something has been done with the Out-take pipe.
All help is much appreciated im alright at electrical but only new to the world of turbo`s and the like so still learning thanks all!!!!!!!
