Apexi FC-Power L-Jetro
22 October 2009
Paisley
www.bebo.com
Hey guys I recently bought a Apexi FC-Power L-Jetro off SXOC that was for a S14a sr20det and was led to belive this was a easy fit to the S15.
Now just found out it isnt quite as easy as I was told :annoyed:
can anyone shed some light on this if this ecu will fit some way or if I am best just punting it on?
Cheers
I was told a while ago that all you have to do is swap some of the pins/wires around in the terminal block (assume its easiest to do that on the loom side) but I don't know which ones..
22 October 2009
Paisley
www.bebo.com
Getting some help on this on drift works as you said craig as far as some of the guys on here is aware :
"youll always need to swap pins round.. the 120 and 1 deg triggers are backwards for pfc..
the pump is prob in the wrong hole and the VTC sol output could also be in wrong place"
I can see me blowing myself up :) woo lol
