Another HID Installation thread
20 May 2008
Hull, UK
raduga-uk.110mb.com
Sorry guys... I can see people have asked about HID installations before and I've taken a look at them.
Since the S15 and my old MX6 use the same bulbs for the headlights, I removed my HID kit from the MX6 with the intention of installing them on the S15.
The bulbs seem to fit OK (if rather snug) but I want to ask about the wiring. Where have people that have fitted the aftermarket HID kits wired in to the exising loom or taken power from? The loom is a lot tidier on the S15 than the 6 and no obvious break in point was visible.
Also, it looks like I'm going to have to 'make a hole' in the cover for the headlamps (the bit you remove to change a bulb) to allow the HID lead out in to the engine bay. My HID's have a gromit on them so I'm not too concerned by this at the gromit will stop any moisture getting in to the unit, but does anyone have a better solution?
I saw this link provided by Nicely in another thread:
http://www.jull.co.uk/mods/hids.html
and quite like the solution there. Anyone know where if anything like this is available? I also like the H4 adapter for connecting the power.
Any help would be appreciated.
Russ
7 January 2007
Perth, Wait Awhile
My HID kit came with two little male connector that is used to tap power from the H1 female connector from the car. I slot it in and just wire tape them together. And for the rear cover, unfortunately the the only way around it is to make a small hole and slide the rubber gromit to seal it in. I've done the same for my kit as well.
