I can get you a guarded switch but it may not be able to take 30A. I'm no electrical expert but I think most things we use have relays so aren't designed to take high current. I'll have a look at work tonight though
If they are like the ones I have at work (I would 100% bet they are) the switch guard is actually seperate to the switch, so all you need is the guard.I had a look but couldn't find anything that will take 30A. The most we have is around 10A.
I think you better relocate it soon as from memory, relays are to be kept in an upright position as they sometimes tend to get stuck. All OEM relays are in the upright so try and keep it that way. Good job nonthelessI might relocate the relay as some point as I put wheels in the boot and they might hit the relay.
I also bought a toggle switch, so waiting for that to come.
Will defo look into that!I think you better relocate it soon as from memory, relays are to be kept in an upright position as they sometimes tend to get stuck. All OEM relays are in the upright so try and keep it that way. Good job nontheless.
