Guys, I've heard the ABS unit is sealed and thus the only way to change the brake fluid within it is to change the brake system as per normal, then go out and activiate the ABS (to release the fluid within) and then re-bleed the system. Any thoughts? I've also heard the system is open and so changing the brake fluid within the system automatically changes the ABS unit's fluid. What do you all think?
