- 26 October 2005
- Helsinki, Finland
- www.jull.net
There has been a bit of dispute recently (not on this forum) over the actual flow-rate of 480cc injectors. Some people will just blindly say its 480cc @ 3 bar. Someone has said that its 440cc @ 3 bar (based on what it now obviously an error in the PFC manual). One thing was certain - no-one knew for sure and no cencrete info could be found. Until now.
I now have the flow-test results from two separate sets of 480s. Mine and another SXOC member's.
Mine returned 540cc @ 40 psi (approx. 585cc @ 3 bar)
The other set returned 528cc @ 40psi (approx. 570cc @ 3 bar)
3 bar is the standard pressure used for injector ratings.
Based on these results, it would actually have been closer to rate them as 555s... However, it is fairly safe to say that if your 480cc injectors are flowing 480cc, they are underperforming :nod:
