- 26 October 2005
- Helsinki, Finland
- www.jull.net
You may find this useful when you need to replace bulbs. There are some quite unusual bulbs on the S15 :nod:
Unless stated, all bulbs are white
Headlight unit
Low beam: H1 (55W)
High beam: HB3 9005 (60W)
OEM HID low beam: D2S (35W) 4300k?.
Exterior
Sidelight/parking: 501 (5W)
Front indicators: 581 (21W - amber) These bulbs have an OFFSET base bayonet
Side indicators: 501 (5W) Although white, you will require amber bulbs if swapping to clear/smoked indicator units
Fog lamps: H3 (55W)
Rear combination lamp
Indicator: 7440 (21W)
Brake/tail: 7443 (21W/5W) Two per side (one per side on ADM S15s)
Reverse: 921 (18W) If a reversing light is converted to a fog light, you will require a red bulb
High mounted brake: 921 (18W)
Number plate: 501 (5W)
Interior
Interior main: 269 (10W) 30mm length
Map lights: 233/BA9 (8W or 10W)
Boot: 501 (3.4W) Although the workshop manual states 3.4W, 5W is going to be much easier to find
Headlight unit
Low beam: H1 (55W)
Exterior
Fog lamps: H3 (55W)
Interior
