- 13 November 2005
- Hong Kong
- www.s15oc.com
Firsly how the standard Oem gauge sits and looks
I know most of u know that but have to say it dont I
Get a flat beded screwdriver either on the side or bottom gently push it in and remove the front face or the plastic which holds the Oem Gauge in..
There one bolt which needs to be undone to get the A pillar off either use a cross headed screw driver or a 10mm
The either use a flat ended screw driver and slowly insert to the side of the pillar and pull gently from the top to remove the a pillar
There are 3 clips which hold it in show in the photo dont use too much force they will just pop out
once i have got that off there are two screws which need to come off before u take the oem gauge out u can use a cross headed screwdriver the unclip the gauge
once thats done u need to cut away the inside off the face which holds the gauge in to let the gauge fit flush i used a small chisel
once that is done need to T in the pipe to here a pic of how i did it as ive got a controller aswell so just cut the pipe a bit then used the T piece and split it into two again...
