Whiteline Suspension Alignment
Whiteline's alignment sheet for the S15 has now been removed from their web site. As many people use this as a setup guideline, I have provided the details here.
Many thanks to Whiteline for forwarding the details to me :)
Jap Heaven
What type of roads would that set up be good for?
Touring would be normal road driving. Race would be track. If you are talking specific road quality, those settings are used in both Oz and the UK.
I've got Touring and want them changed to Sport :)
Pazz
Blast from the past....
Are these settings degrees/min/seconds?
1.5deg = 1deg and 50 mins?
OR
1.5deg = 1deg 30 mins?
(Obviously there are 60mins in a degree.)
Its just that most of the laser alignment kit that wheel shops use are in d/m/s. And the shop that I have been using arent very good with the kit and didnt even understand d/m/s. So when I gave them a setup they had no idea how to match the figures up. (The selection of decent wheel shops is pretty shocking in my area).
Also, why is toe measured in mm? The kit we used measured in d/m/s again.
Matt_S
1.5 deg is 1deg 30 mins.
Just go for 1 deg toe in across the rack. WOrks fine for me.
Darren_S15
Club Event Orgainser
18 January 2008
Essex, UK
Ive got mine set to Touring from there settings and it drives very nice :D
Pazz
When you say across the rack? You mean total rear toe-in of 1deg?
I think i am running 0.8 deg each side.
Matt_S
Yeh. Across the rack.
To be honest, I looked at the whieline settings and thought - ahh fcuk it. I know roughly what difference the toe makes with the drift car experience. The settings I looked at said zero toe :confused:
And toe in gives the car more turn in at the front and stability at the rear, so I went for half a degree on each corner. 1 degree across the rack :thumbs:
U
udi
Bumping an old thread, I'm interested what the "P" and "D" mean in the caster column.
Is it something to do with bushing material? the desired application (drift etc) perhaps?
Larsz
9 September 2008
Netherlands
To revive an old thread instead of making a new one, im getting my car alligned next week! On the rear i have all the arms needed for that and on the front i have a set of DW Tension Rods and Nismo LCA. RUnning Tein SS all around. Now.. the settings found in the first post are those still viable? Because when im getting the car alligned, i hope to set it correct in 1 go :p Any advice you guys can give me?
I drive it fairly hard and roads are good here, occasional track here and there.
Yes, they certainly are. I have recently had mine set up to touring specs but with 2.1 deg rear camber and the grip level is silly. If you like sliding the car around then certainly go for less rear camber!
Larsz
9 September 2008
Netherlands
Im certainly looking into more grip then slip:wack:
I had the alligment measured and its totally off, hence i get it re-alligned and set it for more grippy specs. Cheers craig!
Yep around -2.0 to -2.5 rear camber is good for the front... so much less understeer :)
Toe - personally I'd keep it neutral as it's not something I mess with but you can always start neutral and have a play...
Larsz
9 September 2008
Netherlands
Nevermind, found out the Endlink on the drivers side is FUBAR, going to replace those, together with a nice ARB to go with it!
