Right then..
My box has begun making some rather unwanted noises over the last few weeks which are gradually geting louder and louder. Its a very hard noise to describe so I will add a video clip below (it is the high-pitch metallic ticking sort of noise).
I've searched through every thread related to gearboxes on the forum but cant find a definitive answer to a few questions I have regarding the notorious gearbox issues..
- When the counter rotating gear circlip comes off, is there any noise of notice prior to it happening?
My noise occurs when..
- Driving in all gears, on or off throttle
- Freewheeling in gears with clutch depressed or neutral with clutch in either position
- ONLY occurs after driving 4 or so miles, once the oil is warm I assume.
I recently changed the clutch for an ACT Heavy Duty Organic item, which went well. The old gearbox oil was Redline Lightweight Shockproof, but I refilled with OEM Nissan stuff as that was all I had at the time. Last weekend I had a last ditch effort at fixing it and refilled with the Redline Lightweight Shockproof again, but it has made no difference. There was not a particually large amount of swarf on the mag drain plug either, just the usual amount as to be expected (no chunks!)
My assumption is that it is some sort of output shaft bearing thats on its way out due to the noise and symptoms mentioned above, but cant be sure until the box is off and apart. Luckily I have got a spare 6-speed box lined up incase this one is toast, but would prefer to rebuild this one than fit the spare.
Any advice and experience is more than welcome, and hopefully we can build up a good profile of problems and symptoms people have occured.
Cheers, Craig
Cheers, Craig
