Z32 bmc
22 October 2009
Paisley
www.bebo.com
I think the BMC stoppers show how far some people actually go fair play if your going to track your car etc and you have seam welded everything and reinforced the front arches but its like putting an induction kit on a 1.1 peugeot yea will make a diffrence but it wasnt the best thing you could of spent your cash on :wack:
25 October 2009
oxford
bmc stoppers for the money you might as well use one, unlike induction kits on 1.1 they arn't gunna be detrimental to the performance!
22 October 2009
Paisley
www.bebo.com
end of the day dude if your going to buy one buy one am not by any means saying they dont work, personaly I cant see the point if you dont track or drift your car full time just my opinion :)
5 October 2009
Na I fitted at the same time swapped my stock recirc for a ssqv, fair enough if u tried one but I believe the brakes feel more initially responsive now.
My friend has one on his dc2 aswell which he thinks is worthwhile.. At the end of the day that is what modifying is about, finding what works for you!
Yeah, good point - everyone is different I suppose. I didn't mean any of my comments to be took in a negative way, just couldn't imagine the bulkhead flexing.
When you fitted the Z32 BMC did you feel there was more pedal travel/feel and less sharpness to the brakes?
5 October 2009
I did it at same time as rears and felt a big improvement.. Obviosly takes a while to bed ur new brakes in.. But once this is done you can certainly stop quicker whilst feeling more stable/balanced
This passage from a American s14 site I thought was interesting, I know oem equipment might be slightly different but gives a idea
Driving Impression
Since I did not have the master cylinder when I swapped the calipers and rotors, I had the opportunity to drive the 240 around with the stock master cylinder.* The brake pedal was soggy prior to the brake swap and worse with 3 times as many caliper pistons.* Although the pedal was soggy, it was immediately apparent that the brakes were more effective.* Braking effort was improved as well as fade resistance.*
After installing the*300ZX master cylinder, I fell in love with my 240 all over again!* The pedal feel is better than any car I have ever felt.* The proportioning of the brakes with the new master cylinder is absolutely perfect.* Setup for trail braking and you'll have it.* Panic brake and the car stops true.* I'm absolutely impressed with the brakes.
Good luck, drive safely, and have fun!
http://importnut.net/300zxbrakeswap.htm
GUEST_JDM
do you guys actually know the size of the s15 BMC? if you have a jap spec R which im sure most of you do than its the same BMC as an R33 same piston size same throw, which is more than you will need, i think the best rear brake up grade is to do the hole R33 rear conversion, horse shoe hand brake set up and vented rear disk and 2 pot caliper its a big job but i think the out come would be worth it.
5 October 2009
I have done exactly that guest jdm. R33 rear setup, brakes are better aswell as handbrake is awesome for initiating drifts..
Check this out with regards to bmc
Brake Master Cylinder
Master brake cylinders also differ between models. The brake bias valve is built into the MC body and is not adjustable. Nissan have used both Tokico and Nabco master cylinders and according to my research the models used on various Skylines and Silvias are BM33, BM38, BM44, BM50 and BM57. Nissan used the BM50 Tokico made master cylinder for the S15 turbo. The factory master cylinder of the S15 turbo model should be fine for any of the upgrade options. Upgrading the rear brakes to Skyline 2 pot calipers will probably result in less braking force going to the rears under high brake pressures. The best option would therfore to swap the S15 MC for a BM50 from a 300zx or Skyline BM50. Just remember to get an ABS model MC as the non ABS has different outlets.
Model Type Master Cylibnder Diameter
S15 Spec R BM50 25.4mm
300zx turbo BM50/57 25.4 and 26.9mm used
R32 GT-T M-spec BM50 25.4mm
R33 GTST BM44 23.8mm
R32 GTR non Brembo BM50 25.4mm
R34 GTT ? ?
R32/33/34 Brembo* BM57 26.9mm
* GTR N1 Skylines apparently used the BM50 MC.
Other options to consider
http://nissans15.com/brakes.htm
As you can see I did my homework on this subject lol.. And to top it all off I got the rear brake setup from the skyline for 100 pounds this includes backing plates and shoes but I needed to buy the cables new from db power
Can you remember how much R33 cables were from DB Power?
Cool, thanks. So basically the S15 BMC is 25.4mm but the one to upgrade to is the Z32 or R32/3/4 GTR 26.9 one. Is there any way of spotting the difference between the two Z32 ones?
Does this one look right? :confused: It's from a 1990 Z32 Turbo import.
5 October 2009
That looks exactly what I have on my car mate. I just had to cut the fill Level plug off and attach some new spade connectors and the rest was simple plug and play
Thanks for that :) I'll buy one but try the new brakes with both BMC's to see the difference. What's the normal going rate for them?
21 July 2009
United Kingdom
Rather than start a new topic.....
Did you guys rebuilt your Z32 BMC? I was reading Nicely's web page a few moments ago and it mentions renewing the pistons- where would i pic up a rebuilt kit?
And do you just bolt the BM57 master cylinder onto the stock servo?
5 October 2009
Hi Adam,
I didn't bother rebuilding mine. Just take care not to push piston further normal operation when bleeding. Ie not to the floor as corrosion build up can cut the seals on the piston..
And yes just bolts right up to the servo..
23 December 2010
Devon, UK
Nissan S15 Brakes
The S15 came out with two brake specifications. The turbo has the 280mm discs with 4-pot cast iron calipers. The Autech NA version also uses these brakes. This is the same 5 stud setup as used by the R32 Skyline M-Spec as well as the turbo 300ZX.
The non turbo S15 also has a 280mm disc except it has the more typical single pot sliding style caliper. The brake pad area and disc thickness is also less than the turbo. The non turbo also uses a 4 stud hub.
On both the turbo and non turbo S15 the rear brakes are the same. They are a 258mm non ventilated disc using a single pot sliding caliper.
The best way to upgrade braking performance is just to use some performance race orientated brake pads and flush the old brake fluid with a high quality Dot 4 or 5.1 brake fluid. Unless you're a serious track racer you will be unlikely to require anything more than that.
The only problem is that these days 280mm rotors look small especially if you have 17" or 18" rims. Many hot hatches and sedans are coming out with 300mm plus rotors as factory.Brake Options
While arguably the standard (4-pot) brakes are fine, there are some interesting options to look at for possible brake upgrades. There is the full after market brake setup with big discs and after market calipers. This will cost a lot and some after market kits are not that suitable for every day road use, often lacking the dust seals and generally a lot noisier than factory. Then there are the other Nissan OEM brakes used on the Skyline models. These are generally bigger and can be a direct bolt on replacement.
Only the front R33/R32/Z32 or R32/33 GT-R brakes are a straight swap for the S15. Calipers and discs must go together unless you go with an after market caliper mounting bracket.
All calipers mount to the knuckle spindles in the same way. That means all calliper's bolt holes will line up with the knuckle spindle mounting holes. The bolt will pass through the knuckle spindle bolt holes and will screw into the calliper. Unfortunately with the R34 Nissan changed the thread size which means you can't just bolt on an R34 calliper.
R32 and R33 GTR Brembo brakes should be a straight swap however prices of second hand Brembos tend to be quite expensive and probably not worth the money.
Rear brake swaps are some what more complex and will at least require some custom brake cable modifications to make them work. The Skyline R32 to R34 all use the same rear brake setup. Using the Skyline 2 piston calipers on the S15 will require everything that bolts onto the rear knuckle. This includes the brake cables coming out of the rear hubs. Unlike the S15 the Skyline uses a drum brake for the handbrake which is why you need all the parts. You will also need to make up a small braket to hold the brake cables properly.Brake Disc Specs
Front Discs:
Model Diameter Thickness Center hole height
S15 SR20DET 280mm 30mm 68mm 54mm
R32 M-Spec 280mm 30mm 68mm 54mm
300zx Turbo 280mm 30mm 68mm 54mm
R33 GTST 296mm 30mm 68mm 53.75mm
R34 GTT 310mm 30mm 68mm 53.75
R32 GTR - non V-Spec 296mm 32mm 68mm 54mm
R33-R34 GTR - Brembo 324mm 30mm 68mm 53.75mm
As can be seen all discs all have similar dimensions apart from difference in diameter. All will fit onto the S15 hubs
Rear Discs:
S15 SR20DE/DET 258mm 9mm 68mm 47mm
Skyline R32-R34 297mm 18mm 68mm 63mm
The S15 discs are non ventilated while the Skyline rear discs are. The rear discs are quite different and Skyline rear discs will not fit without swapping over most of the rear Skyline hub parts.
Caliper Specs
Front Caliper Specs:
weights per caliper and do not include pads and bolts
Model Weight Material Thread Pad Piston area
S15 SR20DET 4.8kg Cast Iron 12mm DB1170 40.4mm x 4
R32 M-Spec 3.3kg Alloy 12mm DB1170 40.4mm x 4
300zx Turbo* 3.3kg Alloy 12mm DB1170 40.4mm x 4
R33 GTST 3.3kg Alloy 12mm DB1170 40.4mm x 4
R34 GTT 3.3kg Alloy 14mm DB1170 40.4mm x 4
R32 GTR ? Cast Iron 12mm DB1170 40.4mm x 4
R32/33 Brembo ? Alloy 12mm DB1520 44+38mm x 2
R34 Brembo ? Alloy 14mm DB1520 44+38mm x 2
*The alloy calipers were used on 1990 Twin-turbos and ALL 1991-1992.5 300ZX's (both turbo and non-turbo). 1992.5-1996 300ZX's used same cast iron caliper as S15 (both turbo and non-turbo)Rear Caliper Specs:
weight per caliper and includes brake pads and bolts
S15 SR20DE/DET ?kg Cast Iron 12mm DB325 38mm x 1
Skyline R32-R34 2.1kg Alloy 12mm DB1220 38mm x 2
As you can see all of the front calipers share a common piston size. This means that swapping any of the front over should not mean having to change the brake master cylinder on the S15. The Brembo calipers have a slightly larger leading edge piston compared to the trailing edge however overall piston are is the same.
Nissan made some calipers from alloy and some from cast Iron. All are 2 piece calipers. I'm not 100% sure why there is a difference. Cast Iron would certainly be cheaper to manufacture and would be more rigid. Cast Iron is however quite a bit heavier! Looking at the R32/300ZX alloy calipers we see ribbing which must be to aid cooling. This would seem to indicate that Nissan used differet aluminium alloys with this caliper and that it needs to be kept cool to ensure it stays rigid. Later R33/R34 calipers do not have this ribbing which would indicate that the aluminum alloy could withstand heat better.
Just swapping the standard calipers for 300zx or R32 M-Spec calipers would reduce unsprung weight by 1.2kg per wheel!
The rear caliper swap is as mentioned earlier not quite so straight forward. Apart from the extra complexity of the swap it's also necessary to take into account the brake bias. Factory S15 rear brakes are single piston sliding caliper. The Skyline rear brakes are twin piston calipers and the discs are a lot larger in diameter. The Skyline caliper roughly doubles the piston area. The brake bias valve is built into the mater brake cylinder and can not be changed without changing the whole MC. Comparing 'split pint' and reducing ratios of the S15, R32 and Z32 the split point of the later are lower than the S15 and the reducing ratios are x 0.4. Interestingly the S14 has a higher split point of 569psi and a reducing ratio of x 0.4 even though the S15 is almost identical in weight distribution with the same brakes as the S15. While you may not need to swap over MC, braking distances could possibly end up being longer than for factory brakes.
Brake Weights
Looking at the DBA rotor catalogue we can see the difference in weight between the different discs. The OEM weights I have measured myself.
Model Part # Diameter Weight
OEM S15 Spec R front rotor 280mm 6.7kg
DBA909 - factory replacement 280mm 6.9kg
DBA4907 - 4000 series 280mm 7kg
OEM R33 GTS-T front rotor 296mm 8.6kg
DBA4963 - 4000 series 296mm 7.7kg*
DB42304 - 4000 series 310mm 8.9kg
DBA906 S15 rear rotor 258mm 3.5kg
DB908 Skyline R32-34 rear rotor 297mm 7.0kg
*Unsure why the DBA R33 front rotor should be so much lighter than OEM.
OEM R33 front rotors while only 16mm bigger have an extra 1.9kg in iron. Front brake pads and pins/plates add about 800g per wheel for all brake setups.
Factory brake weights for the S15 turbo is 4.8kg + 6.7kg = 11.5kg per wheel. Upgrading to R33 brakes using OEM rotors would take this to 3.3kg + 8.6kg = 11.9kg. If we belive the DBA rotor weight that's a reduction of 500g per wheel in unsprung weight with the added benefit of an increase in rotor diameter from 280 to 296mm.
The rear brake swap for the S15 will add quite a bit of extra weight over factory. First up the brake discs for the Skyline is a lot heaver and second of all the rear hubs from the Skyline weigh more as they have the drum handbrake setup. I would estimate that swapping to the Skyline rear brakes would add about 6-7kg extra weight per wheel. As for whether the additional braking power at the rear would help much I think it would be fair to say it wouldn't add much benefit. The Skyline brakes would however look a lot better with big rims though.
R34 GTT ? ?
Brake upgrades are all 5 stud so if you have a non turbo S15 you will also have to swap hubs
Rear brake upgrades are possible but are more fiddly to do. Handbrake cabling will need to be fabricated
Aftermarket adapter plates are available to allow you to use your standard calipers with 310mm and 324mm rotors. These however may not be legal without an engineering cert
After market big brake kits with 4 plus piston calipers are common for the S15 if not expensive. Be careful to ensure they are suitable for every day road use
All non Brembo calipers listed take the same pad, DB1170. The rear pads differ but are about the same size between S15 and the Skylines
