Year someone else mentioned that to me the other day, said i needed a multimeter to test it, so im glad that was in the post today when i got home from work, and thanks for the how you go about it part as i was unsure what to do. by the way what does WOT stand for?Did you check your timing and also did you check to ensure that the tps voltage on the throttle is where it should be? The tps on closed throttle should be 0.45V or thereabouts and on WOT should be 5.0V or thereabouts. This can be checked when the car is not running but the key ignition is switched to the ON position and the voltage pulled using a voltmeter/multimeter. The tps should have two screws holding it in position, lightly slacken both and turn to get the right reading for closed throttle and thentighten and recheck that it is good, it car vary quite easily. Then once it has a proper reading check at WOT again and once good that can then be eliminated from the equation. Cost is free so best to check it before you pay to check other stuff.
year thats going to be one of the last things i go for as they arent cheapA complete guess but maybe the O2 sensor??
TPS reads exactly 4.47vYear someone else mentioned that to me the other day, said i needed a multimeter to test it, so im glad that was in the post today when i got home from work, and thanks for the how you go about it part as i was unsure what to do. by the way what does WOT stand for?
ignition set to ON, not started and throttle at closed position4.47V at what WOT or at closed throttle? This should be done when the key is only in the ON position but car is not started.
I made have made a very silly mistake when testing this, ( ive only been playing around with cars for a few months :rotfl: ) i was looking on another website which showed the TPS unplugged, i was testing it unplugged.......Wait throttle at closed position and reading 4.47V? That should never be, it should be 4.47-5.0V on WOT. Maybe you are reading the wrong wire, maybe the positive feed on the TPS. Try when you are reading the voltage to open the throttle and see if the voltage fluctuates, if it does then you have the right wire.
