My daily pearl white
bzh kevin
22 September 2015
bedford
Front end panels came back from blasting and are being prepared for reassembly . It's nice to see some good metal going back on the car :D .
CLEAN_PS_QUARTER_PANEL_1.jpgCLEAN_PS_QUARTER_PANEL_2.jpgRAIL_1.jpgRAIL_2.jpgRAIL_3.jpgRAIL_4.jpg
bzh kevin
22 September 2015
bedford
Yes, everything is getting blasted off so it won't be an issue anymore . The bulkhead would have probably been in a much better shape if the sealant was applied properly though .
More update from HTDevelopments . Passenger quarter panel and rear pocket all sorted and back on the car !
RRQ_PANEL_1.jpgRRQ_PANEL_2.jpgRRQ_PANEL_3.jpgRRQ_PANEL_4.jpgRRQ_PANEL_5.jpgRRQ_PANEL_6.jpgRRQ_PANEL_7.jpgRRQ_PANEL_8.jpgRRQ_PANEL_9.jpgRRQ_PANEL_10.jpg
bzh kevin
22 September 2015
bedford
More update from HTDevelopments . The bulkhead got some new metal and the rest of the front end is getting back together fast .
BULKHEAD_1.jpgBULKHEAD_2.jpgBULKHEAD_3.jpgFR_END_1.jpgFR_END_2.jpgFR_END_3.jpgFR_END_4.jpg
Joeh
12 December 2006
www.silivaoc.com
@silviaownersclub
To say I am impressed is a huge understatement, this car will be better than it did when it rolled out of the factory
Mad respect to the garage carrying out this work, it's hard to find a very skilled workshop let alone one that consistently works on your car days on end.
Keeping my eyes pealed for the next update!
bzh kevin
22 September 2015
bedford
More progress update from HTDevelopments . The engine bay is now back together. The images show a quick test fit of all the front panels before the engine bay get prepped for primer and seam sealant application .
382614385_817025080120868_7469604321963811849_n.jpg382635550_1577592643047192_32519901299260794_n.jpg382005760_273023515556776_4726992672762690801_n.jpg382647041_147512985054851_129362554164169019_n.jpg382694852_1967372256953428_4418799350003482305_n.jpg
bzh kevin
22 September 2015
bedford
More progress photos from HTDevelopments . The car is now on rotisserie, floor is taken to bare metal and repaired are being carried where needed . There is definitely more damage than I thought on the sill . The plan is to get the car painted for end of year and reassembled beginning of next year .
rotisserie_1.jpgrotisserie_2.jpgrotisserie_3.jpgrotisserie_4.jpgbare_metal_floor_1.jpgbare_metal_floor_2.jpgbare_metal_floor_3.jpgbare_metal_floor_4.jpgbare_metal_floor_5.jpgbare_metal_floor_6.jpg
bzh kevin
22 September 2015
bedford
A few more nasty surprises found around the fuel filler neck cutout and the front of the floor that had to be sorted but everything is moving in the right direction!
neck_filler_1.jpgneck_filler_2.jpgneck_filler_3.jpgneck_filler_4.jpgneck_filler_5.jpgneck_filler_6.jpgneck_filler_7.jpgneck_filler_8.jpgneck_filler_9.jpgneck_filler_10.jpg
bzh kevin
22 September 2015
bedford
More update from HTDevelopments . Of course the sills were hiding some more rust, the area was cleaned and some panels will be fabricated next week to finish the job and close off the area .
SILL_REPAIR_1.jpgSILL_REPAIR_2.jpgSILL_REPAIR_3.jpgSILL_REPAIR_4.jpgSILL_REPAIR_5.jpgSILL_REPAIR_6.jpg
bzh kevin
22 September 2015
bedford
HTDevelopments is nearly done with the sills . Next task will be to finish the rear chassis legs and then check behind the driver rear quarter panel . After that this the shell will be ready for painting .
SILL_REPAIR_18.jpgSILL_REPAIR_19.jpgSILL_REPAIR_20.jpgSILL_REPAIR_21.jpgSILL_REPAIR_22.jpg
28 May 2023
UK
Was any of this rust visible from the outside before this work started? It makes me scared to find out what's going on under the paint on mine
