Darren_S15
Club Event Orgainser
Here is my guide on how to fit the Nismo 740cc injectors.
Use this guide at your own risk, but it worked fine for me
When you start your engine bay will look something like this
Before I did anything I REMOVED THE BATTERY CABLES and covered the front bumper and wings of the car with some rags to stop me scratching the body work
1. First we need to remove all the hoses and clips from the intake chamber.
Here is what we need to remove.
> The grey, brown, purple and blue wire connectors
> Brake servo vacuum hose
> Two earth cables
> Dump valve and carbon canister hoses
> Large hose from the cold pipe
> Two throttle cable holders
> Boost take off
> Earth cable bolt
2. Next we need to remove the throttle body bolts from the intake chamber by undoing the four allen key bolts.
Note: The bottom two bolts are awkward to get anything onto. I had to undo the coupling hose from both the throttle body and the cold pipe and push the coupling hose back down the cold pipe to give me enough room to get a socket in. I also unclipped the connector on the throttle body to give me more room.
The work shop manual has an order to do these bolts up so I removed them in reverse order (4,3,2,1).
> Two earth cables
> Boost take off
> Earth cable bolt
