Jay-pan
Hi guys, just been to a rolling road to have the car checked out to see if its running okay.
When on the rollers it produced 180hp/160ftlb at 0.7bar of boost. Which to me seems very low but was told theres a 20-30% transmission loss also had a boost leak around the intake manifold. Also was told I'm running lean 12-13 which is the big issue. But they said its running spot on with no flat spots and produced a perfect curve graph starting at 2200 - 6500 where it dropped off.
So far my mods consist of
HKS GT RS TURBO
HKS Adjustable Actuator (No standard boost control unit)
Tubular Manifold
555cc Nismo Injectors
Uprated fuel pump (Don't no make yet)
HKS 3" down pipe
HKS RSK air filter
2.6" Nismo PRO-Spec exhaust with cat
Z32 MAF sensor
Oil cooler and relocation kit
Standard BOV
Standard FMIC
Standard boost (0.7)
To be fitted
HKS SSQV
Japspeed FMIC
Just wondered if anyone can help with what to do next to make it safe? and also what kind of management could i be running?
Checked the ECU which is standard but has two wires coming from the plug which have a connector on just lying in the footwell (white and Blue) so could it be chipped? or what other options are there?
HKS GT RS TURBO
Tubular Manifold
HKS 3" down pipe
HKS RSK air filter
Z32 MAF sensor
Standard BOV
Standard FMIC
To be fitted
HKS SSQV
Japspeed FMIC
