FS: my breaking thread. tonnes of expencive and hard to find parts
sx-si
7 June 2008
hampshire uk
New additions
S14/15 whiteline antiroll bars
£125 each or £225 for the pair
rear is rusty
Engine spec:
• Arias Piston Kit
• Eagle H Beam Rods
• ARP Head Stud Kit
• Brian Crower Stage 2 Camshafts (IN 264 and EX 264)
• Brian Crower Uprated valve springs
• Cometic Metal Head Gasket 1.6mm
• Lightweight Aluminum Pulleys
• Head ported and matched intake and exhaust
• Polished greddy style pletnum - doesnt have sticker so im assuming its not genuine
• Polished water in and out pipes
• Poweder coated black chrome mounts and bits
• New vvt sprocket fitted
ill try and dig out the pics from when it was built
im looking for £2500 nnow £2150
i dont have the black sparkalie cam cover
only a pearl white s15 one, stock black s15 one ore a stock s14 one
Turbo/ignition
• Spitfire ignition packs for s15
£250 now £245
• Blue silicon hoses on the water system
£50 posted??
• db power 52mm rad (new)
£150
• S15oc carbon fiber slam pannel
£100 deliverd its not perfect but had stickers covering holes and cracks
..Breaks/Wheels/Tyres..
• larger front break setup with rebuilt s14 calipers (think its 330mm)
db power break spacers
m3 drilled and grooved front disks
ferrodo front pads (unsure what pads but i think there frredo)
braided lines
£300 ono
..Transmission/Exhaust..
• 5zigen full exhaust
£350 now £340 ono
• apex 3in decat silancer
£100 now £95
• getrag jaguar manual gearbox conversion
custom prop
custom bellhousing
sierra cosworth (rwd) 6paddle clutch
will accept £2250 as its a builitproof box now £1650
• Nismo 2way r33 gtst diff
in s15 casing with speed sencor fitted
also included are r33 half shafts
£650 now £600
..Suspencion/Steering..
now Available
driftworks 20mm extended spacers for steering rack
• driftworks toe arms
£100 ono fitted but new condition
• cusco camber arms
£100 ono
• cusco tencion rods
£100 quite rusty now £90 ono
carbine ali strut brace
cost me over £200 but will accept £150
..Interior/Electrial..
• Touchscreen DVD Player (deh-p4000dvd)
Bluetooth Phone kit
Full iPod control and USB port
will accept £450 now £425
• apexi boost gauge (new in box)
• apexi oil pressure gauge (new sencor)
• apexi oil temp gauge (new sencor)
• apexi water temp gauge (new in box)
• apexi exhaust gas temp gauge (new sensor)
• apexi fuel pressure (no sencor)
apexi controller
will accept £550 deliverd now £505 deliverd
• phormula ks4 knock meter with light
£250 (new)
• hks turbo timer
£25>?
• HID 6000k headlight system
very small ballast (new) £50
hks limited edition 6-speed gearknob
£25 now now £25 deliverd
polished turbo inlet 60mm
sx-si
7 June 2008
hampshire uk
braided lines
£300
£350
£100
custom prop
custom bellhousing
will accept £2250 as its a builitproof box now £2000
£650
This wont be available for a couple of weeks but can take deposits
• tein rods and ends
will include a spare set of ends £160
• driftworks front geo knuckles
driftworks rear geo knuckles spec2
20mm offset rack spacers
looking for £800 as the rears have never been fitted now £750
£100 fitted but new condition
• cusco camber arms
£100
£100 quite rusty
• Cusco fully adjustable coilovers with camber adjustments zero2
cost over £2000 before you even think about import taxes
one of the best coilover ive ever used and fo some reason they have been on uk roads for a while and locking rings still spin fine
im after around £900 ono
• carbing titanium Rear strut brace
•doluck middle brace (s15)
cost me over £350 but will accept £275
Bluetooth Phone kit
will accept £450
apexi controller
will accept £500 deliverd
£250 (new)
• hks turbo timer
£25>?
Hks limited edition oil cap
£35
metal steering rack bush's
£20
£25
db power abs removal lines
unsure if its all there so £30
roll of fire proof suff
£25
sx-si
7 June 2008
hampshire uk
rear subframe locking collars
£50
driftwors rocker arm stoppers
£75
fuel pressure regulator
£50
screamer/ wastegate pipe
£25
throttlebody
£35
s14 larger diff backing plate
£100
fmic pipes from greddy inlet plenum
£75
apex small washer bottle for fmic install
£50
sx-si
7 June 2008
hampshire uk
altecians- yes should do by the weekend
tooley and sam - because i sold the shell, and its worth 20k in bits or less than 15k finished
i got debts to clear and want my own place
also ive seen a 1jz candy red s15 for 10k
Mike
16 May 2010
Interested in the hid kit mate, it come with everything needed to slap it on?
sx-si
7 June 2008
hampshire uk
yeah should do buddy
geabox conversion dropped to £2000
engine now £2250
driftworks geo knuckle setup now £750
J.C.AUTOSPARES
Hello im looking for 2 front headlights, bonnet and passenger wing can you help? or maybe know some who could ?
regards
J.C.
